Oil Thermostat Operation
At what tempature does the oil thermostat open?
Should there be a small flow through the device when its cold? |
There is NO SUCH CREATURE.
I was thinking the same thing, where on earth would that be lol. Please rephrase coolant thermostat!
actually I have seen oil thermostats before...they do not open or close persay, but talk to the computer and can be and sometimes are another gauge to look at.
On these I5 Volvo's?
I suppose multi-viscosity engine oil could be thought of as a passive oil thermostat...
I don't think this is what you are asking. :P |
Originally Posted by Turkey_Sandwich
(Post 307407)
I did read that an 850 does have a thermostat but I can't remember if it's in the trans cooler circuit or the engine oil circuit ?? It might be engine oil since they only use the engine oil cooler on the turbos. One of those things I was curious about but hadn't yet tracked it down. It's supposed to keep the fluid from circulating until it's reached close to normal operating temperature. In colder climates they want it to get up to temp sooner so they bypass the cooler when first started. |
(Post 307585)
Do What ??
(Post 307585)
Originally Posted by Henry10
(Post 248049)
I cut the steel lines post-thermostat and connected them to each-other with a rubber hose, i.e. oil cooler is not used. This is a temporary solution. I am looking into the correct piping/hoses and fittings, since I will no longer use Volvo OEM lines.
According to Volvo literature oil pressure is minimum 14 psi at idle and maximum is 43 psi at 3000 rpm. This is the same for 850 NA and Turbo ('95-96); again I have both 2.4 and 2.3 Engine Volvo's documents and pressures are the same. However, I understand that the lubrication system for Turbo is different from NA, and the oil pumps are different Part Numbers (at FCP). Maybe someone can explain this? From other research I have learned that 850 Turbo oil pump's capacity has been increased by a wider pump wheel and a modified profile. Yet, Volvo documents show that both pumps push the same psi pressure. Regarding Oil Thermostat: it starts to open at 203 degree F oil temperature and is fully open at 300 degrees F oil temperature. I'm not sure if this is a major problem unless you live in a very cold climate and/or do not let your car warm for a couple minutes before driving. |
(Post 307607)
It was a dorky engineering joke.
"From other research I have learned that 850 Turbo oil pump's capacity has been increased by a wider pump wheel and a modified profile. Yet, Volvo documents show that both pumps push the same psi pressure."
That's because the turbo (the turbocharger itself) uses up a lot of oil. The reason the part numbers are different is because the turbo pump will pump a higher volume of oil at the same PSI and RPM than the NA part will or needs to. The turbo's oil pump parts are physically bigger to pump that higher volume. The rotor in the pump is the main source of volume and the maximum pressure is usually controlled by a spring that limits max PSI. It's like having a 1" hose running to a NA and a 2" hose running to a turbo. They both are running at 14psi at idle but you'll get a whole lot more out of the 2" hose. It needs that extra oil for all the oil that flows into and rapidly through the turbocharger to both lubricate the bearings and carry away heat. |
1 Attachment(s)
Well that was an interesting read, I can assure you there is a oil thermostat on 850 turbo models. http://www.fcpeuro.com/products/volv...enuine-3528199
It is located in the 5:00 oclock position near the Crankshaft damper. If you have a a non-turbo model there will be a block off plate installed there. Attachment 18355 |
Well, I learned something NEW today. Now to my question... How in the world are you suppose to know when that thing is bad?
