Possible Relay Issue ?
Just a quick one for all the experts on here. When I go to park the car and turn the key off I get a buzzing sound from the fuse block/relay area under the hood and the battery light filckers until the buzzing stops. No other dash lights come on when this occurs. Any help would be greatly appreciated as this is one of the last items on my list. Thanks in advance.
Anyone ????
Give us a little time. All of the really smart people are at work. :)
Did not mean to be rude. I myself am at work also just trying to pass the time.
Pop the cover off of the fuse box (4 T-25 Torx screws) and then just feel the relays until you identify the one that is chattering. From your description my guess is that it is one of the overload relays which are the small ones marked with nothing more than J.
Beyond that you may have an issue with the battery line to the fuse box itself. ...Lee |
Originally Posted by Ozark Lee
(Post 289226)
Pop the cover off of the fuse box (4 T-25 Torx screws) and then just feel the relays until you identify the one that is chattering. From you description my guess is that it is one of the overload relays which are the small ones marked with nothing more than J.
If that isn't it, then may have an issue w/electrical portion of ignition switch but would think you would see other issues too if it were that... |
Thanks for the info I will try that in the am. Once I find the one that is chattering is it a simple swap and replace or could there be more to this problem ?
