Problems after chipping V850 2.3T5 (SOS!!!)
#21
is there a chance some one has the ACCURATE vacuum hose diagram- 1 have 2 different ones - and have no idea which one is right - the one under the hood is pathetic-i need a step by step connection diagram for every vac line -if there is one --by the way --UPDATE ON ENGINE REBUILD ! its all back together and im waiting on the belt tensioner - but now i found the water pump is shot - it was not more than a year old belt is new pulleys are new - i guess the water pump freeze plug leaks coz of all the high pressure that was built up in the engine in the past - that caused the head gasket to blow and the oil seals all popped -please advise if any info- is it possible to replace the freeze plug on the water pump??
#22
And about BCS. Are there non stock for higher boost pressure?
#23
#24
#26
#28
#29
#30
Well, it is quite simple to do when you have wastegate removed, but when it is installed in the car it becomes almost impossible to do this. Or am I wrong?
#33
#34
#36
Might it be that my problem is related to leak of pressure somewhere in system? I think in that way: turbo boosts some pressure, air goes through MAF, but somewhere a little part of pressure goes out, so there is a misstatement between MAF indication of air flow and other parameters which ECU indicates, so ECU turns service regime (lowers boost for saving engine, 4-1-4 boost pressure too high). When MBC is installed, ECU can not reduce boost, but it sees misstatement, so I get fuel cut.
Do I predict correctly? Because DTC 4-1-4 often appears when air leaks somewhere.
#38
#40
i have a T motor - at least thats what is says on the manufacture plate on the driver side wheel well
B5234T - 854T #34 OFF THE MANUFACTURING LINE ----- WOOT!!!!
I DONT WANT TO F^&* THINGS UP AFTER ALL THAT WORK
I HAVE THE WIERDEST MOTOR CYL 1 IS -D.2 IS D. 3 IS E. 4 IS E. 5 IS D.
most engines ive seen for volvo all pistons are either D or E mine is mixed is it a screw up ??
omfg it jumps so quick without the turbo set right - i gotta go easy
the other thing is my boost needle is at 1/4 instead of at the white line is that ok??
im thinking vacuum leak ---- AGAIN
