Prosport Boost Gauge Installed
#21
K&N doesn't have an application for the 850s per say..... You can buy the cone, but no arm to attach from the filter to the MAF. Also if you DID get the arm, and the filter, you still have an issue of warm air from the motor going right into the air filter, which u want colder air for the performance. That's why most kits for the 850's have that barrier around the filter. it blocks some of that warm air and helps guide the colder air form the outside to the front of the intake. TECH did show me this.. It's just as good as the IPD but less expensive. It's on my wishlist for my 850..http://www.eurosporttuning.ca/mm5/me...Code=VL-850-en
#25
I am going to make the shield out of loose-leaf paper.... just kidding of course
I was thinking of making it out of plastic. Just to find some big sheet of plastic and cut to the dimensions you need. Then seal it with a caulk. The shield as you can see with the expensive filters is not really high tech.
Where can I order a 3" pipe? Link Please?
#26
#27
here is what I did..... https://volvoforums.com/forum/intake-headers-exhaust-21/first-performance-mod-21483/
Spectre's website: http://www.spectreperformance.com/#CATALOG (Flash)
The piping is next to the filter, so next time your there or another store, pick some up. Ten you will need a silicone reducer if it is not a 3" MAF. This site is pretty good to get stuff from..... http://www.siliconeintakes.com/
Plastic trash bins are very fairly simple to use and it already has sealed edges, just need to let it touch the hood.
Get some High heat spray paint, to add the extra protection and it will look nicer.
Also those are oil filters. If you dont want to use oil filter then go with AEM Dry flow. more money........
#28
#31
#32
#33
#34
I did a How to make Poly bushings for my swaybar endlinks.....Your's are ball joints(I believe) so that doesn't apply, but if your daring to try other parts.......
CAI don't really gain you that much Gains for these cars can very from 2-15hp.... It lets the turbo take more air in faster then the stock setup, which should net slightly better throttle response, and you should se very slight MPG improvements. The real fun comes from the sound. you really hear the turbo spooling, but the best part is you will now be able to hear the stock CBV. nice pssssh sounds of the gas...
You can go ahead and get a K&N filter for they have one in every size, so no reducers are required.
Yes I have the P4 model.
The Exhaust combind with an intake will be good. But it really helps once you get a Tune.
The hardest part making the sheild is finding a good object/material to use.
#35
#36
I didn't know that you were able to hear the turbo better by doing that. That makes me wanna do it that much more now. haha. About how much did that set up cost you that you have?? And with that extra intake down by your bumper, is that a problem with rain or excess dust or anything??
The bumper setup is the best alternative to moving the filter outside the engine bay. Since my filter is more towards the side and the forced bumper pipe is point straight. The filter stays very dry. I tested it by sparying water up the bumper. The only thing.....Be a little more carefull driving through BIGGA$$ puddles.
My car is older then the 850's and has less sound reduction crap in the car. so the turbo sound will very....It is right by the driver so It should still be good to hear.
#38
#39
MUST have an aftermarket boost gauge. Then open the hood adjust it untill the boost level is reached. slight turns...
#40
Sounds easy enough. Although I would probably maintain stock boost levels since the turbo is older, something possibly for the future. I'm definitely going to look into a CAI though. You have any opinion on the K&N air filters for the stock box, I know they're not going to provide the same performance as a cone.
