Puzzling 850 stall and no start issue
Here is what happened.
Have had a slight sputtering/lack of power issue on my 95 850 NA 5speed wagon. Thought it might be the MAF, tried to replace that and when I put the new (non Bosch) part in it wouldn't Idle and cut out under anything more than 1/3 throttle. yesterday I was driving and when I came out of a store and got in the car to leave it stalled on launch. It happened 1 more time within a couple minutes. I then pulled up to the light and when I went to launch it stalled and would not start. It sputters after let off the throttle albeit very slight. Previously replaced. Plugs Wires cap Rotor Fuel Filter What I have checked Spark to all cylinders Fuel pressure above 40psi on the rail Timing belt not broken Cam shaft is not snapped checked the Throttle position sensor (a week ago before the car stopped) Also tried the Floor it and crank it for 30 seconds to 1 minute I am at a loss as to what might be going on. any thoughts? |
Do you have a cel?
Originally Posted by rspi
(Post 342948)
Do you have a cel?
If you have a code you need to go from there. If not you likely have a fuel pressure problem, like a bad fuel pump relay.
(Post 343005)
So it is not the Crank Shaft Position sensor (replaced it no start)
All of the injectors are powered and operating No CEL Still have fuel pressure I am going to try switching out the coil as it is old and even though I am getting spark it may not be enough for ignition. |
