-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Radio problem, Volume control (https://volvoforums.com/forum/volvo-850-16/radio-problem-volume-control-10784/)
ncstatecamp Mar 30, 2007 12:29 AM
ok so i have a 97 850 and im having the oddest problem, my radio glitches out where if i try to turn the volume down it turns up, mostly only when i try to turn it down alittle, so it doesnt happen all the time. The only way to fix it is to turn it firmly and rather quickly. if anyone has any ideas please tell me!!!
axelm Mar 30, 2007 12:33 AM
RE: Radio problem, Volume control
Use electronic contact cleaner to clean the potentiometercontrolled bythe knob. You might have to remove the radio and disassemble it to do this.
JPN Mar 30, 2007 03:37 AM
↑+1
JPN
SkyWriting Dec 29, 2010 10:40 AM
Originally Posted by ncstatecamp (Post 54020)
OK. So i have a 97 volvo 850 and im having the oddest problem, my radio glitches out where if i try to turn the radio volume control down, it turns up. Mostly only when i try to turn it down a little, so it doesn't happen all the time. The only way to fix it is to turn it firmly and rather quickly. If anyone has any ideas please tell me!
My volume control is the same. After I cleaned it with spray, one front speaker works at lower volumes and the rest only work at higher volumes, unless we use "Technicial Tapping" on the volume knob with a finger nail. But at least one speaker will provide lower volume for a change.
Repair pictures here:
http://www.matthewsvolvosite.com/201...volume-switch/
jorn mulder May 12, 2022 02:21 PM
Yes weirdly even if i put my foot on the gas or the clutsh foot. and also if i turn the nob on the radio, sometimes volume go's up and down by itself if i don't even touch radio or controls on steringwheel.
i gonna open it and take out the radio, maybe loose cables? don't know.
btw can you put in any car radio in that part? can i put in a new radio? or will that not fit ?
Greets, Jørn Mulder
jorn mulder May 22, 2022 04:37 PM
yea i will try that. have to ask my dad first it's his car. :)
mt6127 May 22, 2022 07:32 PM
850s use a standard "double DIN" sized radio and you can find adaptor connectors on eBay or google for the factory connector pin out. Swapping in a replacement Volvo radio is pretty easy as well provided the unit you buy comes with the code or the donor car VIN. Just press the two vertical tabs on the outside and the radio slides right out - no tools involved... I guess that's why they need a code LOL
