Fault Code 453
Fault Code 453
I used the diagnostic unit to determine some fault codes. The one that is concerning is code 453. I understand that means there is a misfire on cylinder 3. Would that be a result of a bad fuel injector? I recently had to do an extensive clean and replace on the PCV system which included removing the fuel rail. I didn't replace any of the injectors at the time because I am cheap and this car doesn't mean a lot to me. The fuel injectors came off rusty and obviously warn. Would that likely be the reason for my misfire?
As always thanks for any assistance.
Adam
Adam
elchingon2002
03-11-2008 10:41 AM
