Removing glovebox arms
RE: Removing glovebox arms
You will think you are going to brake the thing, but you probably won't. You will see a little notch where you need to stick the screwdriver. Facing the dash it's on the right side (almost certain)on both arms. Be very careful to not lose the arms into the dash once you get them loose from the door. The are slippery little suckers.
