rough running with tps code. help. SOS.
car is a 96 glt 5speed and has had a misfire for awhile and has progresses to multiple cylinder misfires. tps code high input comes up. changed the tps sensor and when that did not work i changed the harness plug.
any ideas? computer malfunction? thanks shawn |
RE: rough running with tps code. help. SOS.
Mightbe a comupter problem I have seen it before. Remove the computer and clean connections.
| All times are GMT -5. The time now is 11:03 PM. |
