A sad day indeed.
So, I just got my 1996 volvo 850 turbo wagon running, after I replaced a valve, lapped all the valves and replaced all valve stem seals/full stage zero(timing belt, plugs, wires, cap, rotor, thermostat). Boy was she a strong runner, for the whole day it was running. I do admit to abusing it quite a bit. But what else would you expect from an 18 year old kid who just rebuilt his first volvo engine ? Now, i will note that the car had horrid previous owners, that took no care of the car(ran it low on oil and who knows what else). I know I ran it out of oil once, on the way home from buying it.....the guy did not put the oil filter on tight enough, and it blew the oil filter seal out. Luckily volvo's have low oil sensors. Anyways, to cut to the chase; My engine sounds like this one(note video is from another member on this forum).
DSC_8277.mp4 video by paintballfreak14 | Photobucket Now i have to do all the things i just did to it... but also the bottom end. So what i am thinking is... since i am taking the engine apart all the way, Why not build it so that this wont happen again?. So i am going to put in forged pistons/rods, glt cams, R manifold, bigger turbo, bigger injectors/fuel pump. But then comes the fact of an automatic transmission, i know it cant take all that power, so i need to do a manual swap(Tons of fun weekends right?)and i have never took a transmission off an engine before, so that will be fun. So all in all i was pretty sad and depressed that i blew up my volvo. One of the cars that i truly love. I can say, for certain; i would rather have a volvo 850, than a corvette, mustang, sweet truck, or any other awesome car you can think of. I feel better now that i have gotten those things off my chest. If anyone has any tips or ideas to help me on my way, please feel free to throw them at me. Thanks a bunch, Predxen |
Does it only make the knocking noise when you give it gas? Are you running 91+ octane? Sound like a knock to me.
Did you do a compression test? |
Originally Posted by rspi
(Post 341978)
1 Attachment(s)
How big a turbo and what tune ECM ?? How much horsepower do you think you'll be making ??
An automatic should be good for up to 300. Modding your 2.3L FWD Turbo Volvo 850, 70-series [Archive] - Turbobricks Forums |
(Post 341981)
Unfortunately a video does not give direction as to where the knock is coming from. Are you sure its coming from the cam area? If so that is sure better than the bottom end. Let me run this by you. The oil path that runs through the valve cover is pretty small. Suppose when you put the sealant on there was an excess that plugged or partially plugged one of the oil feed lines that pressurize the hydraulic lifters for the valves, the lifter collapses. At low RPM there is not much noise but when you rev it the gap becomes larger and the cam lobe slaps the cup. Just a thought. You might want to invest in a mechanics stethoscope and see if you can pinpoint where the noise is coming from.
Right On Boxpin. I hear the same type of noise, what I sometimes call valve slap, which is a result of ... lifter clasped...improper value adjustment (mechanical lifters-not applicable here). So I like boxpin explanation of how this could have happened. That is where I would focus with use of good listening tool as he described.
Good luck. We all have learned from our mistakes, which makes us smarter for the next assignment. |
Originally Posted by boxpin
(Post 342011)
Would plugged oil passages cause blue smoke ? i had a lot of blue smoke coming out of my engine the whole day. I thought it was the turbo burning oil. But could plugged oil passages cause this ? i have new valve stem seals in, so i know its not that. And if a lifter is collapsed, will adding ATF to the oil clear the oil passages, and pump up the lifter, as rspi suggested in another post ? Or is the lifter Wasted and needing to be replaced ? also how will i know which lifter is broke ? It will be seperated from the cam if it is collapsed, Right?
Band-aid
I really think the first thing you need to do is purchase a mechanic stethoscope and find out where that noise is coming from. |
(Post 342075)
Band-aid
Well, what was wrong with the Volvo in the video? Has its owner figured anything out?
This is all a work in current progress.
I never posted that ATF will clear sealant from the cam cover passages, it will sometimes flush out a little oil gunk. |
(Post 342122)
I never posted that ATF will clear sealant from the cam cover passages, it will sometimes flush out a little oil gunk. Agreed, it has cleared up some sticky valves for some. Me included but it wont break through a sealant. |
Cam cover is off, only took me 4 hours instead of 1.5 days to do it the 2nd time. but i dont know what passages go to the lifters. Also i have no clue how to see if a lifter is bad. I have had a long day, i got home from work at 6:30, it was dark and 8 degrees Fahrenheit. i started at around 8, and am just getting done, at 12:30 am. Boy am i tired.
1 Attachment(s)
I think it's a little cold to be working out in the garage (unheated) today. It's sitting at 3 degrees right now.
i am looking at the lifters, yet i have no clue how to tell if they are bad or not. Also i was wondering if there is supposed to be a little notch, where the cam sits. its where the intake cam sits, on the opposite side of the cam sprockets, just inside from where the cam seals go, there is a notch about 3mm wide, and 12 mm long, where the cam sits, is this for the oil to drain back....or is it from no oil being there and the cam burning a hole through?
****Uh, did you pinpoint where the noise was coming from before you did this?****
-Well, now that you have the cover off. Pull the pucks out, flip them over and push on the center, it should move and feel spongy. If they are solid and dont move they should be replaced. -Then, put some pressure on each valve and look for possible broken springs. -Get an air compressor and blow out the channel that feeds each lifter, make sure they are clear. -Look at the valve cover and you will see the channels that the oil travels, look for anything that might block the oil feed. |
(Post 342261)
