Service light/bad milage
1997 855 t-5 with 133k miles
my service light comes on for about 1 min than goes off every time i start the car i been getting ****ty milage for the last month had new plugs wires cap rotor oil change i done full tune up about 3 months ago any 1 have any ideas thanx
The is a Service Light, which tells you when to change your oil and a Check Engine Light which means you have a code in the ECU. It sounds like you your light is just the service light, which is not an issue. Your bad mileage could be a few things, more then likely a vacuum leak. I would check all the intake hoses and lines for cracks and leaks and repair them as you find them.
well im getting like 15 city/highway and i was getting 21 city/highway
i will check for leaks but the oil if fine hope its just a leak thanx for input
Yea that is pretty bad.I get 25-28ish hwy when just cruising and around 15-19 if Im driving hard.
Thats with 17psi tune,OBX turboback etc.
yea i never seen more than 24 i think dont even drive hard
d00ver
Sep 13, 2012 10:50 PM
