Speedo showing incorrect speed.
Hi guys,
On my 94 850 T5 I have a slight issue with the speedo. It constantly shows as 10km/h under what the actual speed you are doing is. Eg: needle says 60, I'm doing 70. When the car is stationary, it points exactly at zero, where it should. When I do a cluster test in OBD1 port A7 the needle goes up slightly less than verticle (about 10km out). The rest of the cluster works fine. Is this a case of replacing the cluster, or should I attempt to move the needle slightly off zero to compensate? Are these needles a pain to try and adjust? Thanks for any tips guys. |
What size tires & wheels are you running?
Originally Posted by Brick850
(Post 363922)
When the car is stationary, it points exactly at zero, where it should. Are these needles a pain to try and adjust? When you say it points exactly at zero, do you mean the actual zero, or the line that indicates zero? There's a bit of space between the two. I had lined mine up with the actual zero, but when I checked my other car I found that the needle should be above the actual zero, pointing at the line that indicates zero. I had to take it all apart (:mad:), but now I've got it aligned so the car and the GPS both tell me the same thing. The needle pops off if you put a flat screwdriver behind it. Do it carefully. It's easy to break, but it will come off. Be careful pressing it back on too, obviously. |
Thanks for the reply guys. The forum did not tell me I had any replies. I have now fixed the problem. It turned out the needle was resting too low and pointing directly at the "0". I looked at various you tubes and have now reset it to point at the first line when stationary.
It now reads spot on. |
