-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   temp gauge - engine temp sensor (https://volvoforums.com/forum/volvo-850-16/temp-gauge-engine-temp-sensor-52633/)
blackbrick Apr 15, 2011 03:13 PM
This morning I noticed that as soon as I started the car Temp gauge was showing normal working temp and radiator fan was on. Car sat in garage over night and there is no way engine stayed hot for 10 hours. Is this mean that coolant temp sensor is bad?
Also battery died yesterday and I replaced it. Not sure if this is connected.
Any input is appreciated.
MattyXXL Apr 15, 2011 04:50 PM
If you unplug the sensor what happens?
blackbrick Apr 16, 2011 12:03 AM
We'll see tomorrow. It's my day off so I will have time to deal with it.
Car has about 240K on it so I will probably replace sensor and thermostat
blackbrick Apr 16, 2011 01:25 PM
When unplugged sensor, temp was showing that engine was cold and raised slowly to normal but fan was on all the time even with engine off.
ibified Apr 16, 2011 02:22 PM
sounds like maybe the car put itself into limp mode. disconnect the battery for half an hr or so then reattach and see what it does.
blackbrick Apr 17, 2011 01:34 AM
I did it and no change, it still shows that engine is warm when start the car. There is no difference in car performance, still drive like champ
blackbrick Apr 20, 2011 01:53 PM
It is showing right temp now. It did it by itself, not sure why or how it was reading wrong temp. but since yesterday everything is back to normal. Anyways, going to replace thermostat and sensor soon.
blackbrick May 7, 2011 01:38 AM
Today I replaced ETS and thermostat and upper hose. I was amazed how clean coolant was in there. 15 years old coolant looked like brand new. It took about hour to do the job
hookuspookus May 7, 2011 01:46 PM
the reason it was so clean is because it was distilled water NEVER use tap water :D
