top speed limiter?
top speed limiter?
I was out in the country going to go look at a 1980 242 and i came across a very nicely paved road. So i decided to see what my wagon could do. Got up to 100 real quick but was then slowly creeping to 110. It wouldnt go past 110 I was at wot and doing 110 for at least 15 seconds and would move no more... So you could probably guess the question... Why would it not go past this speed? Is there a limiter? Anyone else have this problem?
For North America it is limited to 142 mph. It's unlimited elsewhere. There was an article somewhere I looked it up once and the Turbo wagon could do something like 155 to 166 mph unlimited? when it first came out. That was done in a close course oval circuit. Heck the speedometer in the UK are like up to 160 mph.
It hasn't lost that much if it will smoke The tires off in second. If it was low on HP it would still build speed my car just completely froze at 110.
Smoking the tires at a gear change (in which the road/tires are basically arresting the engine which has gained much rotational inertia, from a higher RPM to a lower one, via a higher gear ratio) is not the same thing as steady state power.
You could be limited because the computer is pulling spark because it sees knock and is trying to keep you from burning a hole in a piston.
Man, every one of our turbo cars would whip past 110. I had our S70 GLT up to about 12) and it was still picking up speed, had already proven my point to the Maxi that didn't want to let me pass. I had my 960 up to 11*, it was stuck there, lots of weight in the car (vacation). I have seen 13) in my daughters GPS (the S70 GLT). I had my yellow sedan up to about 12) and it was still bitting. Have not had the wagon over maybe 9) yet.
I actually was thinking that you had a NA car which would be about the cars HP limit.
I just did the ccomplete ignition tune up with all oem componets. I run 91 octane because that is the hightest I fan find in Iowa. I still have the misfire I mentioned on my previous post. I think I'm going to get a new fuel filter and regulator I think that's the problem with my misfiring situation and the fuel filter/ regulator would definately limit your top speed at least thats my theory.
When my car was bone stock I got up to 147mph, I think all auto/manual T5/Rs are limited to 155mph.
After my ecu remap, I got to 156mph..vid below:
. - YouTube
From all the "professional" reviews i've read over the years, turbo auto HPT volvos seem to top out at 150, 155(governed) with the manual. LPTs stay around 125-130mph.
. - YouTube
But ... like Turkey Sandwich said, you might be having some knock which would pull back on timing and leave you with nothing to accelerate with. Hopefully you're using premium and hopefully it really is premium (little bit of paranoia every time I pass a gas station and I see an unbranded tanker dumping it's load )
I'm just guessing. But if you get a chance to do it again try to get into fifth gear and keep the boost at 8 or less and see if it pulls more MPH. If others are hitting 130 or more as they've stated here, it's likely you're hitting fuel cutoff due to boost. As always, if you buy an upgraded ECM that can all be changed
I've already ran chevron techron and didn't seem to help much. I just put seafoam in for the hell of it. The fuel filter looks original, I don't know why some people think they don't have to change it lol. I've already ordered the filter and I'm just gonna wait on the fuel regulator and see if its just the filter.... Ipd wants 125.
#17
My guess would be you bumped into fuel cutoff because of the boost. If your ECM is stock you were in the range where the ECM would step in to keep the system from putting itself in danger (in it's mind).
#18
For some people if it isn't in their face they have no clue. As that filter is under the car I'd venture to guess there are some out there that have no idea the car even has one.
I still have arguments with guys who want "the stuff for a tune up" and want to fight about the fact they want wires, cap and rotor on a vehicle that is coil on plug. They just have no clue.
#19
. - YouTube
. - YouTube
