Tough time removing the fuel filter
Having a really tough time removing the fuel filter. I cannot disconnect the quick-release couplings. Anyone have this issue and any recommendations? Do I pull the coupling away from the filter or push it towards the filter to disengage and allow me to remove the tubing? I tried both and either way I can't get it off. Any tips?
Thanks! |
What year ??
97 850 na
Got er done. The quick connect tabs should be pulled AWAY from the filter. Used a 17mm wrench to do the job relatively easy. I kept the underside bolt in place when I was disconnecting the fuel lines as this gave counter-traction to pulling on the lines.
In the past few weeks I have replaced the front passenger side motor mount, transmission torque rod, plugs, wires, distributor, rotor, transmission fluid, air cabin filter, and fuel filter (all parts from FCP) and this car is running smoother than ever. Thanks for all the help on this forum! It's been a lot of fun and very satisfying to work on this car. |
fuel line connectors
Originally Posted by rspi
(Post 364996)
Thanks for all your help dohboy |
Originally Posted by dohboy
(Post 383840)
It would be helpful if you could demonstrate the removal of the fuel line connectors from the filter,:rolleyes: in detail, this is the difficult part if you are not knowledgeable about this process.
