Trip meter upgrade
Hello I have a base model 850 with a only a clock on display on my cluster. I want to install a trip meter. Do I need any other hardware or sensors aside from the display, switch, and harness? Thank you
No you will not but there is a few different ones make sure you get the proper one.
I have an extra one if you need it. PM me. Display & Switch.
ScanGauge is really helpful if you cannot use OEM parts on your model.
I can improve 3 MPG by watch out the gauge. You can save more if your foot is harder then mine :-) |
It came from a 97 850 turbo. I have a 96 non turbo. I don't know if this detail is important-mine does not have a sunroof lol! I can post a pic if that helps
It should work out ok
Yes it should work ok.The main ones that are different are the earlier cars.
can anyone post a link on how to remove the gauge cluster and how to replace the trip meter? ill work on it today. thanks!
[IMG]javascript:;[/IMG] |
http://memimage.cardomain.com/ride_i...0002_large.jpg
here is the item im about to install to my 850 |
thanks!
