Turbo Issues
I am hoping that someone can either confirm or debunk my suspicions about an issue I am having with my brick.
I am working on a '96 850 Turbo, and have noticed a lot of water coming out of the exhaust lately as well as the coolant recovery tank blowing up like a balloon with the cap on. If I take the cap off there is a lot of bubbling going on, and it increases as I rev the motor. When I turn the car off, the level of the coolant in the tank drains out. Suggestions? |
Sounds like the headgasket might be blown.
Is the oil milky looking? You might also want to do a block test to see if the headgasket is blown. |
What do you mean by "Block Test"
I have a compression tester for the cylinders, and the oil is messed up but I didn't have that problem until I pressure washed the front of the engine so I didn't have to work in the goo. I have a feeling that I have an ancillary issue with the crank seal that is causing my oil leak but that is an issue for another post later on if I have to jump off that bridge. |
did you pressure wash a hot engine???...
by block test he means leak down test.
Originally Posted by nonsense619
(Post 168043)
And I have a buddy that will be doing the leak down test in a couple days so I guess I will know more then. |
No by block test I mean you get a setup from a local Auto parts store like this.
http://images.google.com/imgres?imgu...3Doff%26sa%3DG If the fluid changes color from blue to green or yellow the headgasket is blown and exhaust gasses are getting into the cooling system. |
