Turbo kicks in early in park.
Old 01-05-2007 | 12:10 AM
RedTurbo850's Avatar
Default Turbo kicks in early in park.
So I was reving my engine, and the turbo kicks in almost immediately. Which is not right.
I remember I did this back a couple months ago, and when I revved the engine, there would be no turbo in the "black" and turbo once it hit the white or at least a louder sound once it hit the white.
Now however, the turbo kicks in immediatly when i'm in the black. It doesn't even go up to the white.
I read the code yesterday, and apparently I have an RPM sensor problem (Crankshaft position sensor). Could the turbo kicking in early be attributed to this problem, or is it an entirely new problem?
Old 01-05-2007 | 01:14 AM
Default RE: Turbo kicks in early in park.
Possibly if the computer disabled some of the systems due to the code being present.
Also is the boost control valve good.
Do you have higher boost?
Old 01-05-2007 | 01:48 AM
ORIGINAL: tech
How can I find out if i have higher boost w/o a boost guage?
I think my turbo kicks in fine when i'm driving though, but i'm not compeltely sure.
Old 01-05-2007 | 01:59 AM
But up top you said you have a guage on the dash. If you had more boost the guage would go higher.
Old 01-05-2007 | 03:28 AM
ORIGINAL: tech
Ooh. Gotcha. I can hear the turbo spooling hard when i'm reving but the guage doesn't indicate that i have higher boost.
On the highway, the car seems to be normal, with the guage going to white and stuff.
P.S. I thought you were referring to a boost guage which tells me how much boost I got. But I gotcha now.
Old 01-06-2007 | 12:44 PM
I would check the Vaccum hoses between the boost control valve and the turbo.
Old 01-06-2007 | 10:58 PM
Could this be that my broken RPM sensor is making the turbo kick in early?
The RPM sensor is sending incorrect info, and the car thinks that it's time to boost/
Btw, how hard it is to replace the RPM sensor/Crankshaft position sensor and how much would this part cost?
Old 01-07-2007 | 12:02 PM
Pretty easy to replace not sure about prices though.
Old 01-07-2007 | 04:48 PM
^Ok. I was talking to my friend. Could it possibly be the plugs? (I'm reading a transmission code 3-1-1 which has to do w/ the RPM sensor). My friend said it might be the plugs (?).
Where does the part go? In the crankshaft? Because that is hard to get at (?)..
Old 01-07-2007 | 05:38 PM
I doubt the plugs are the problem.
I will have to do some searching tomorrow to find out exactly which one it is.
It might be the sensor in the top of the belhousing or the one in the transmission itself.
Old 01-08-2007 | 08:33 PM
Alright thanks tech. The Crankshaft position sensor/RPM sensor are the same thing correct? So there is only one location....???
Old 01-08-2007 | 10:14 PM
Well it could be either the Cam sensor or the Crank sensor or the transmisison sensor.
Take your pick LOL
Old 01-09-2007 | 12:02 AM
^So the 3-1-1 (RPM malfunction code) refers to 3 possible things?!?!??!
Old 01-09-2007 | 12:57 AM
I will have to try to remember to check tomorrow at work.
The book I have at home is only a cheater book.
Old 01-09-2007 | 01:43 AM
http://volvospeed.com/vs_forum/index...howtopic=47502
This is where I found my code. Look under A1.
Old 01-09-2007 | 09:47 PM
Sorry forgot to look very busy One guy short.
  #17
Old 01-10-2007 | 12:09 AM
^LoL. Not a huge problem. Most likely gonna try to get this fixed over the long weekend.
Imma also take the car in to get all the hoses and what not checked (20$). Someone else told me that my turbo boosting early may be attributed to a leaking hose...
  #18
Old 01-12-2007 | 12:02 AM
Bump?
  #19
Old 01-12-2007 | 11:20 PM
Sorry keep forgetting.
Nothing found on your end?
Wrote it on paper have to tape to my steering wheel for MON.
  #20
Old 01-15-2007 | 10:52 PM
Ok, from what I understand, the RPM sensor/Crankshaft position sensor is located below the airbox and it's relatively easy to replace?
So do I just remove the airbox, unscrew the nut/bolt (whatever is holding it) and then replace it? Sounds like a quick job?
