turbo timer wiring?
hey guys i was wondering what wires do i hook up in the ignition to run a turbo timer? i have a turbo timer with a universal harness . what wires hook to what?
green wire?
red wire?
blue wire?
whie wire?
i was wondering if you guys could tell me what colour wire hooks up to what wire under the dash in the ignition?
i know one wire goes to the e brake ground and one wire goes to the o2 sensor .
its a 96 850 turbo 5 spd.
green wire?
red wire?
blue wire?
whie wire?
there is no volvo section in the instructions . goes through all makes from acura to vw but no volvo.
and found out from hks that that dont make a turbo timer harness. so i have to use the universal harness.
If you post the colors of the turbo timer harness and what wire it is suppose to go to then we could probably help you out. Most of your connections will just be to the wires going to the key cylinder. None of us will know the wires on your timer harness unless you tell us.
I understand that but it should still tell you things like needing an ignition wire and ETC.
Then you would look in the diagram for the wire you would need.
I eventually plan on adding one but not till I get a 19T turbo and get it in there.
They should have given you a paper that says something like Green goes to power source or something like that. That's what we need to know to tell you where it would go on the car.
I know that one wire will go to the brake light switch but only the book for the turbo timer will tell us what color from the harness that will be.
LOOK IN THE MANUAL, and tell us which wire is supposed to go to what, for example:
Red to battery
Green to Ignition Power
Blue to Parking Brake
White to Ignition Coil
then we can tell you where to locate each wire.
Red to battery
the book does not say anything about what colours wire goes where. and actually there its only 3 colors wires. red , green , blue and they dont say where thoise wires go. or even says what wire is power and what one is acc etc.
the book doesnt say much.
black wire goes to ecu ground , white wire goies to o2 and grey goes to e brake bround.
cheesecake
Apr 27, 2010 06:51 PM
