Upgraded my front end...
I just upgraded the front end on my 93 850 sedan with the front end from a friends 96 wagon (he blew his motor and didn't want to find another so I bought it for parts) My car is US Specs and his is Euro specs so when I hooked up the headlights I didn't have the wiring for the dip beam connection however, when I was messing with the dash I found the wiring on mine for the switch that controls the dip beam, can anyone give me some help on hooking up the wiring for the dip beam? I just need to know where to route it into the car so it will work. The switch lights up when the headlights are on so I'm pretty sure there is power to it.
Also what other Euro only/94 and up parts are good upgrades for mine? I already pulled the front sub frame and rear axle so I can change to 5 lug wheels and (with any luck) have a good rack and pinion for the steering I can use on mine since mine leaks real bad. Thank you all for your assistance. Josh |
