Volvo 850 n/a manual: Car shuts off after long drive,oil light flickering. Plz help?
Hello guys!
My 1994 850 manual. non turbo is a nice clean sweetheart with a pampered 240k miles. just lately, after a longer, say 30 minute drive in the hot 105 degree texas heat, the car shuts off by itself when you get to an area where you need to decrease your speed or rpm. Then, when you turn the car on again, the engine runs a tad rough and the oil lights starts fLickering. after you leave the car alone and let it cool down for say 30 minutes the problem goes away and the car starts acting normally again. This problem just recently started happening when the temperature in austin is unbearable. im thinking it has something to do with heat, but my temp needle shows on halfway and the car seems happy and not overheating. oil pressure is ok also I think... There is plenty of oil shooting up when I open the oil cap at idle anyway... This SAME EXACT scenario has happened twice today...
Do you fine folks have any insight into what the problem could be? My 240 is currently being painted and my wife and I are sharing the 850. it would suck to be down to zero cars. can you guys help?
I really appreciate the help!!
Thanks for the reply, I'm running a mix of 10-40 and 20-40 oil... makes it 15-40 I suppose... I don't see any oil leaks anywhere... Car's engine is dry as a bone. Even at idle, when you open the oil cap, oil shoots out like nobody's business, with zero blow-by... I can't imagine the oil pump is bad.
does it run better now that you fixed the fpr vacuum line? The oil blowing out the cap sounds like a blocked PCV system to me.
Sounds to me as if you may have had 2 separate problems, and with fixing the vacuum line, you have addressed ONE of them. Check that PCV - pull the oil dipstick up a little bit and see if smoke comes out of it. if it does, replace the PCV and your oil issues should go away as well.
zandrew
06-01-2014 10:50 PM
elijahs40
06-20-2011 11:32 PM
DecalService
06-19-2011 09:25 PM
