Volvo 850 vOlume on rAdio not working
Old 03-07-2004, 12:50 AM
rAcing_VoLvOs's Avatar
Default Volvo 850 vOlume on rAdio not working
what can i do with the vOlume turn diAl, the music gets louder as i try n turn it down</P>
Old 04-01-2007, 12:48 AM
Default RE: Volvo 850 vOlume on rAdio not working
yah i have this same problem if you get a fix pleasae tell me
Old 04-01-2007, 01:18 AM
JPN's Avatar
JPN
JPN is offline
Default RE: Volvo 850 volume on radio not working
Hi,
Seems like the POT (potentiometer, a type of variable resistor often used for audio volume control) is acting up. Try taking the radio out, pull out the volume **** and spray air duster first, then a tiny bit of electrical contact cleaner. Also, spray a tiny bit of the cleaner into the connector couplers, connect &amp; disconnect several times. If you can dig into the POT further at your own risk, you could spray a tiny it of the cleaner directly into the POT. I repeated "tiny bit" many times, as all you need is, well, a tiny bit. Too much spray will cause more troubles than a fix.
A gentleman by the name of "Axelm" could give you better solutions than I could; Axel is the electrical/electronic wiz kind of guy.
I hope it helps.
JPN
[IMG]local://upfiles/6892/E722C464EBB54051A1DBB5719DFACE2A.jpg[/IMG]
Karen
02-14-2022 07:47 PM
arni76
11-15-2014 10:36 AM
TheVolvoMan
04-26-2004 10:07 PM
chipg2
04-18-2004 09:46 PM
TheVolvoMan
04-18-2004 08:44 PM
Quick Reply: Volvo 850 vOlume on rAdio not working
