What is the back spacing, offset and bolt pattern for a Volvo rim?
Do any of you know the back spacing, offset and/or bolt pattern for a factory Volvo rim?
RE: What is the back spacing, offset and bolt pattern for a Volvo rim?
5x108 is the bolt pattern. Not sure about the others.
Have you used the Volvo Forums Resources Thread at all? Do you know it even exists on this forum? If not you need to check it out.
https://volvoforums.com/m_38606/tm.htm Within there you shall find a BOLBED section titled VOLVO RIMS. Check that out. It should help you. Also your not giving us much info. What Volvo rim? Any Volvo rim? Because some Volvo's have different bolt patterns and certianly some have different offsets. But an 850 uses a 5x108mm bolt pattern. |
