What is this... Pic included...
Can anyone tell me what this is? I'm new to 850's and I have no idea with this hose is.
https://volvoforums.com/forum/pictur...&pictureid=686 It was like this when I picked up the car. The cruise control did not work at all and I found a vacumme hose elbow open just forward of the firewall which allowed the cruise work a little. A little means that it engages about 3 to 4 mph below what I set it and it has a 5 mph range while it is engaged. |
think that line hooks up under the intake hose from the BCS on the turbo models?
What is a BCS? I am asking about the orange tip thing that looks like a vac hose connection.
There should be a nipple at the bottom of the intake hose (the big hose in the picture) where this tubing to go to. but, I am trying to imagine that someone might have ended up breaking that nipple and minght hae improvised this orange link to connect this tubing to intake hose. So, this orange thingy might have to go into a hole on the underside of the intake hose that was left by broken nipple. Just try to feel a hole on the bottom side of the intake hose very close to where this tubing is and push this connector in there.
1 Attachment(s)
i agree with bestharry.probably a quick fix.
BCS stands for "BOOST CONTROL SOLENOID" here is a picture i found on volvospeed.your line attaches to the area i circled in red...the nipple is capped in the picture...but like bestharry said you can feel it under the intake hose...hope this helps |
