Wheel Lug Compatibility
Have a 94 850 and 98 V70
Can anyone tell me what other wheel lug patterns are compatible? Looging on Craigslist for winter tires/wheels and there are alot out there for S60/S80 etc. Thanks, Chris |
They're all 5x108, just depends on the offset and I dunno if the bore size is different between the cars or not.
I seem to remember that the 94's had a 4 lug hub. If that is the case then you wouldn't be able to switch wheels. If they are both 5 x 108 then fitting would not be a problem. Just try to keep the offset similar.
I would suggest going to a junk yard that has volvo's and get a set of wheels there. Then get some winter tires for them. They have some good ALL SEASON tire out now that may work for you as well.
I can remember a while back that iPd or some company sold some studded snow belts that were easy to put on and take off for those bad snow days. |
Originally Posted by jks2
(Post 189099)
Pretty much every Volvo ever made was a 5x108 with the exception of the 93 Volvo 850. Also, all the FWD cars and the Volvo 960 have the same offset.
93 or 94, I couldn't remember. Thanks for the correction.
Thanks FCP, and everyone else too. Got an drier/accumulator from FCP, worked great...thanks!
Chris |
the s40 (2000-2004) has a four lug setup. i think the rest are 5 lug
All the way until 2004 the S40 was four lug??? Weird.
i *think* so. the early builds were 4 lug as far as i have seen. 05+ were the late builds.
Originally Posted by gilber33
(Post 189239)
See: http://en.wikipedia.org/wiki/Mitsubishi_Carisma for more info. |
