Will a 94 turbo head fit a 96?
I have a head from a 94 turbo and wanted to use it to replace the head on my 96 turbo. I know a lot of things are grouped into the years 94-95 and 96-97 is the head one of them? Thank you in advance for any help!
Yes
Mitsubishi TD04-XXX The exhaust housing is the same for all. It will go right in. The only thing you need to check is the oil and water fittings. There were in different places for different years but I believe 94 and 96 are the same. |
Is it the engine cylinder head you are asking about ??
Yes, the cylinder head. So it should swap? If lines are in a diff place would they be relocate able? Thanks again, Bob.
| All times are GMT -5. The time now is 12:57 AM. |
