2009,C30, 2.4i Headlight washers
Hi,
I have recently lost the R.H. headlight washer cover. What is the procedure for fitting a new cover, (hopefully without pulling the front bumper off)? Does the cover clip onto the washer nozzle? If so, is it prudent to replace that item at the same time? You suggestions will be gratefully received.. |
Originally Posted by CCRD
(Post 473688)
Hi,
I have recently lost the R.H. headlight washer cover. What is the procedure for fitting a new cover, (hopefully without pulling the front bumper off)? Does the cover clip onto the washer nozzle? If so, is it prudent to replace that item at the same time? You suggestions will be gratefully received.. I did a little googling and can't find any good diagrams. Looking at the replacement part, it looks like it just clips to a mating piece on the nozzle. Depending on how you lost yours, you might need to replace the nozzle as well, if the clip on it broke when the cover came off. No idea how easy or not this is to do. |
