C30 Model Parts
Hi, i've just bought a 2010 C30 RDesign, and it pretty much needs an entirely new front end, i was just wondering if the parts from an 09' model would fit the 10' one, as I have seen quite a few front driver side wings going up to 09' but none past.
I was just looking for some help on what to buy, any help would be much appreciated, thank you. |
when you say new front end - what parts are you expecting to replace? tie rod ends, control arms, struts, strut bushings, sway bar bushings etc?
What I'd do is use a dealer web store and get the factory volvo part numbers then search online to see what years those part numbers fit. Are you thinking of taking parts off a donor car vs going new? Not sure if I'd do that just to save a few bucks considering all the effort is in the labor and now you have the labor to remove from the donor and remove install on the new. If you expect to keep the car for another 100K miles, go with OEM or genuine Volvo replacement parts (no cheap after-market stuff). |
