Can't start "Please turn wheel try again"
Hi everyone
This morning I was not able to start my C30. The display shows "Please turn wheel try again". The steering is not locked. Every time I move the wheel, just a tiny bit, I hear 3 clicking noises. The noises origin appears from the steering column/wheel. I can turn the key to full ignition but the car will not start. Everything else in the car works. I can only hear what I presume is the fuel pump whenever I try ignition.
I have been searching the internet for people with similar problems and I have found a couple of cases that almost matches what I am experiencing. There just wasn't any real solution. Therefore I am trying here as a last resort.
Has anyone experienced anything similar? If so what was your solution?
My last resort of course is to have the car towed to a Volvo auto shop.
Thanks
Thanks
on
1 Post
You have not stated whether the engine is capable of cranking over or not?
If not, it might be the PNP switch on the transmission.
Paddling the gear shifter a number of times up and down between Park to 1st and back sometimes cleans the contacts allowing the engine to then turn over on the starter as normal.
PsychoForJesus
03-07-2017 11:22 AM
kandio
09-07-2007 05:22 PM
