Volvo C30 - Issues with Cutting out/Stalling Under Acceleration
Old 06-06-2017, 07:06 AM
Smithysmudge92's Avatar
Exclamation Volvo C30 - Issues with Cutting out/Stalling Under Acceleration
Hi there,
New to the forum, having trouble with my 09 plate 1.6D Drive SE C30.
Under acceleration the car seems to cut out / stall. No warning lights come up on the dash apart from like a stall but takes a few seconds after loss of power.
Recently had trouble with DPF Filter and Pipes but repaired around 6,00 miles ago.
Any help would be greatly appreciated.
Thanks
Old 05-28-2018, 01:26 AM
rib_shady's Avatar
Same here, the problem kicked in after one hundred thousand km. It does this especially when going uphill on the highway or accelerating hard at higher gears. Very annoying especially because you feel every time the car could die on you.
With the A/C on is even worse.
Adam240
07-10-2014 08:04 AM
carpy
12-03-2011 07:36 PM
benschumacher
08-13-2010 02:43 PM
volvo 4 life
08-15-2007 09:48 PM
Quick Reply: Volvo C30 - Issues with Cutting out/Stalling Under Acceleration
