Engine Management
Hi all, first post so be gentle.
I'm hoping you may be able to help work out whats going on with my engine before having to take it in to my local garage and get charged an arm and a leg in labour for diagnosing. Approx a month ago I noticed the engine management light show on my 2010 Volvo C30 T5 R-design, I plugged in my Fault Code reader to find it was stating:
Any thoughts would be appreciated. |
sounds like the fuel pressure sensor needs replacing. You didn't mention what engine or year car but check out Volvo friendly parts sites like FCP Euro or EEuro Parts. It should be a 15 minute fix (vids on Youtube). Part should be under $50 for OEM Bosch, over $100 for Genuine Volvo...
Anyone?... Anyone?... Bueller?
Call the garage again and set an appointment.
If the fuel pressure sensor is out then it probably has a default to at least keep the car running, but the pressure is probably too high for idle.
You can either guess and try and fix this yourself or seek a professional. I do not recommend that DIY projects include any fuel related work because of the hazards involved. Pay for a proper diagnosis and repair. |
