Volvo c30 2.4i fuel filter location
Hi, I having problem locating fuel filter on my car. Maybe someone can help me with that?
Ialready checked there. I watch all youtube videos and searched the web, but nothing. Is it possible that it is in fuel tank or fuel pump, because I find some forums where people said it?
what is VIN for your model? You may not have an external serviceable fuel filter on your car.
2007 2.4i petrol
yv1mk385972019893
I found this; "This is one of those models with on demand fuel systems where the fuel filter is integrated with the fuel pump unit. However, some models may continue to use external fuel filters. Therefore, you should first check for an external fuel filter. If it is not present, the fuel filter is probably integrated and if you need to replace it, the entire fuel pump would need to be renewed" so if your car is running fine, leave it as is. If its not, you'd have to consider replacing the pump.
Here's what your VIN says about your car: Manufacturer: Volvo Car Corporation Manufacturer Address: SE-405 31 Goteborg Sweden Product Type: Passenger Car Make: Volvo Model: C30, S40, V50, C70, New V40 (CC) Body: Coupe Check Digit: 9 Model Year: 2007 Plant Country: Belgium Sequential Number: 019893 |
OK, thanks. But I think it's very strange thing not to use an external fuel filter
