2008 C70 AC works for a while and then stops
I own a 2008 C70. The AC will work for about 30 to 40 minutes and then quite. Blows good and cold when working. Had it to a mechanic they could not find anything wrong. Could this be the low pressure switch? Seems like when first starting car it works. After about 40 minutes stops blowing cold air.
I
Originally Posted by wingrolr
(Post 449384)
Have you tried to change the low pressure switch? I have one coming I am going to try that.
The compressor clutch is worn out.
