black smoke!
Old Jun 23, 2010 | 07:00 PM
jar22187's Avatar
Exclamation black smoke!
We have an 01 c70 convert, with 170000miles. After long trips it goes into a rough idle and large amounts of black smoke come out of the exhaust when accelerating from a stop, with a hint gas? like its running very rich. Its about 90 degrees so thats out of the question. HELP!!
Old Jun 24, 2010 | 01:34 PM
willseph's Avatar
Black smoke tends to mean you are running too rich and burning fuel. Have you noticed a drop in MPG? Any check-engine lights? I'd guess you have at least one injector not functioning properly.
Old Jun 24, 2010 | 06:01 PM
vz909's Avatar
Default You Over Fuelling!
Acceleration / Black Smoke -> Over Fueling! - should light up lambda light (O2 sensor code) Lamda light (it's the upside down Y, on dash light) Use a OB2 code reader and should tell you the problem(s) you need to fix
Accelleration / Blue Smoke -> Burring oil! wore ring(s) causing oil blow-by. Wore Ring's self explanatory...
Start up / Blue smoke -> wore valve seals, Oil leaks past valve seal pools on valves and smokes when started after sitting. Valve seals can be replaced about $1 each.
cronny1
Sep 1, 2011 08:33 AM
erock0284
Jan 24, 2011 07:35 PM
xxblindxx
Jun 7, 2010 07:06 AM
nub0t
May 18, 2010 09:57 AM
Ruskya Mafia
Jul 28, 2009 09:42 PM
