Braking steering vibration.
Hi. Hope someone may be able to help me. When applying the footbrake there is a terrible vibration. I have replaced both track rod end and one inner tie rod but problem is still there..
When going at a walking pace no vibration at all. Any suggestions please. |
most likely you have warped brake rotors. try jacking the car up and rotate the wheels by hand to see if you can feel the pads hitting a high spot. Its sometimes hard to tell if the issue is the front or the rear rotors.
