C70 Not charging BUT no warning light
Hello, I hope I haven't jumpt into the wrong place, I'm new to posting questions. I have a 2003 C70 which has just had it's second alternator fail in just over a year. The odd thing is there is no warning light coming up on the dash - any suggestions? Thanks
You had posted in the 850 section so I moved your post over to the C70 section.
Please go into your profile and add your location. It might make a difference in what people recommend you try or where parts might be available. Have you had the battery tested to make sure it's good ?? What were the symptoms you had, did you do the testing on the alt or a shop ? Did the second one fail completely as in no output or is it not producing it's rated output ?? |
