clear headlight
For the headlights you will need to find some for a 2003 C70.
For the window GOOD LUCK most likely bad window regulator.It is like $300.00 for the parts and like 4 hours labor.
http://www.vptuning.com
http://www.vivaperformance.com/parts...70_turnsig.jpg
70 Series Clear "Jewel" turn signal lenses
[VP-1070US] $99.99
Click to enlarge
On 2003+ C70 convertibles, Volvo updated the turn signal housing design to a more modern clear "Jewel" unit. We now carry these turn signal lenses. Will fit on all S/V 70 series from 1997-2000, and 1998-2002 C70 series without any modifications. Comes in a pair.
http://www.vivaperformance.com/parts..._headlight.jpg
70 Series DOT-spec "Jewel" Headlamp Kit
[VP-1056] $709.99
Click to enlarge
Select quantity:
This product was added to our catalog on .
70 Series Euro spec Clear "Jewel" headlamps
[VP-1050EU] $923.99
Click to enlarge
On 2003+ C70 convertibles, Volvo updated the headlamp design to a more modern clear "Jewel" unit. We now carry the Euro spec 2003+ 70 series headlamps that utilize the more popular HB3/H7 bulb designs. These Euro spec headlamps have a sharp light cutoff to minimize any light glare, and help illuminate road signs and sidewalks much better than the US spec headlamps. The popular HB3/H7 bulb designs and Euro light pattern makes it easier and safer to retrofit high intensity discharge (H.I.D) systems, or any other high performance bulbs to these headlamp units. There is also a small 'citylight' lamp built into the low-beam unit. Complete headlamp units come in pairs for left hand drive vehicles. Will fit on all S/V 70 series from 1997-2000, and 1998-2002 C70 series without any modifications.
**For Offroad Use Only. Check local and federal laws for lighting regulations. **
http://www.vptuning.com/parts/catalo...headlight2.jpg
http://www.vivaperformance.com/parts...ner_lenses.gif
70 Series Euro Turn Signal Lenses
[VP-1030EU] $157.49
Click to enlarge
U.S. spec S/V/C 70 models have an undesired amber insert on the side of the front turn signal lamp housings. Now you can upgrade to the look of European spec OEM Volvo turn signal lamp housings! The lenses are high quality units made by HELLA, a leading Original Equipment Manufacturer of lamphousings and headlamps. They are a straightforward install with no modifications required.
Select quantity:
Also FCP Groton sells U.S. DOT clear turn signals and headlamp lens's as well as the E-code clear turn signals and headlamp lens's.
http://fcpgroton.com
As for taillights good luck finding any, I know of no one who makes them.
[VP-1070US] $99.99
Click to enlarge
[VP-1056] $709.99
Click to enlarge
Select quantity:
[VP-1050EU] $923.99
Click to enlarge
[VP-1030EU] $157.49
Click to enlarge
Select quantity:
