covers for Wind Deflector holes
I have a C70 convertible 1999. There are open holes on the passenger and drivers side back seat where the wind deflector plugs into. Are there covers for these holes? I'm not sure if there weren't covers to begin with or are mine just missing. If there are covers, any suggestions where to get them??
I accidentally had posted this under V70, and the website mentioned in the reply unfortunately didnot have any covers.Thanks for any help!!! |
RE: covers for Wind Deflector holes
I have a 2000. and mine clips into the side panel behind the door, above the arm rest. Its got a fairly descrete cover on it already.. Are you walking about the gap in the headrests where it meets the seats?
I'm confused, but I've never seen a '99 either.. S. |
I guess I should have been more discriptive! The holes are on the upper third of the sidepanels.They are maybe the size of a quarter. I bought the car used and in addition to not having the wind deflector, there are these holes! Do you have any idea if there are covers for them? Or any suggestions? Thank You!
The holes I have look like a 1.5" x .5" slit, with a circular hole in the centre ( looks like an old school plane propellor) That is the trim cap for the hole. If thats missing you have a large gaping hole. Which is very unsightly. If you already have the trim cap which accepts the wind screen ( which you should) seeing as its screwed on with a torx screw. Then you cannot cover up the small hole itself. Except with a windscreen which is my sugestion.
s. |
Thanks for the info. I must be missing the trim caps!!! It doesn't look pretty! Any idea how to find some?
Dealer got it for me for a few bucks.
S. |
