Desperately need pic of a C70 antenna ring harness
2 Attachment(s)
Hi all,
I need a picture of the harness that connects to the antenna ring. I'm helping a friend figure out a starting/stalling issue with his '04 C70, and we took the connector apart to rebend the female contacts a bit tighter. Unfortunately the wires pulled back out of the green connector body before we got the connector snapped back closed, so now I'm not sure which wire goes where in the connector. I suppose a wiring diagram or just an explanation of the wire colors could also work. By the way, the wire colors on this car are red, orange, pink with white stripe and pink with black stripe. Thank you very much for any and all help! When I'm done I'll be sure to make a detailed post outlining what all we did to (hopefully) successfully fix this starting/stalling issue, which I'm sure will help another member down the road. |
Darn, I was really hoping for more help with this.
I really need a picture or two of this harness so I can help my friend get his car back on the road. I'll pay a $20 bounty via Paypal to anyone that can either find or take a good picture of the harness/connector. It only takes a minute or two to pop the steering column cover apart to snap a picture... |
2 Attachment(s)
It's crazy how nobody here wanted $20 for 3 minutes of work. Anyway, I finally found a C70 in a local junkyard and was able to snap some pics for myself. Posting them here in case anyone ever needs them in the future.
