how much boost in c70 hpt
Hey guys,
How much boost is there in a hpt c70, a 99 in particilular. What about a lpt for curiosity sake.... and can u increase boost in a light pressure and get the same results? thanks |
RE: how much boost in c70 hpt
I do not know at what boost the hpt and lpt run, but I know that you could not simply up the boost on the lpt to make the same power. I don't know if they are technically the same engine or not, but even if they are, you would need at least new injectors and the engine management system re-configured/replaced to get the right A/F mixture in there.
Look in your owner's manual................I believe the answer to your question is in there Reg ORIGINAL: c70turbogt Hey guys, How much boost is there in a hpt c70, a 99 in particilular. What about a lpt for curiosity sake.... and can u increase boost in a light pressure and get the same results? thanks |
The boost is usually set at 5-7 from the factory.
The 5-7 PSI, sounds more like an LPT engine
HPT should be like 10 or something. Because I know my 2.4L I5 LPT 99 S70 awd stock was 5-7 PSI. ------------------------------------------------------------------------------------- Of course the HPT will gain more over LPT in Torque and Hp. However you can up the boost on an LPT model. I did. Just get a ECU upgrade. Check into IPD, RICA, Upsolute, Speed Tuning USA. I have the Speed Tuning USA ECU upgrade on my 99 S70 awd and have it raised with their 12PSI program. You can also try a MBC (Manual Boost Controller). However I don't recommend it, because it isn't as accurate and not reliable. The ECU upgrade is. ECU Upgrades http://www.vptuning.com (U.S. RICA dealer) http://www.ipdusa.com http://www.speedtuningusa.com/ http://www.upsolute.com/eng/index.html http://www.eurosporttuning.com |
VPTuning.com's Info on C70 ECU upgrades
Model Power (bhp) Standard Torque (lb/ft) Standard Power (bhp) Upgrade Torque (lb/ft) Upgrade 1998-2002 C70 LPT 190 199 238 280 1998-2002 C70 HPT 236 243 294 295 2003-2004 C70 LPT 197 210 235 266 2003-2004 C70 HPT 242 243 294 301 VP-7011 Motronic 4.4 ECU #608 C70 2.3L HPT, 1998 (5-speed manual) $749.99 VP-7012 Motronic 4.4 ECU #607 C70 2.3L HPT, 1998 (automatic) $749.99 VP-7014 Motronic ME7 ECU C70 2.3L HPT, 1999-2004 (5-speed manual) $895.99 VP-7015 Motronic ME7 ECU C70 2.3L HPT, 1999-2004 (automatic) $895.99 VP-7010 Motronic 4.4 ECU #458 C70 2.4L LPT, 1998 (low pressure/automatic) $749.99 VP-7016 Motronic ME7 ECU C70 2.4L LPT, 1999-2004 (automatic) $895.99 RICA is the most exspensive, but highly regarded as the best. IPD's Info on ECU upgrades C70 T5 A/T 1998 +$1000 CORE Motronic+ for ECU #607 (automatic) WS607 $795.00 3.0000 BUY C70 T5 M/T 1998 +$1000 CORE Motronic+ for ECU #608 (5-spd) WS608 $795.00 3.0000 BUY http://www.ipdusa.com/pdf/ecu_94_98.pdf EST's Info on ECU upgrades C70 2.4L LPT 1998 - 2002 ECU Upgrade C70 2.4L LPT 1998 - 2002 ECU Upgrade Code:VLE-275-064 Price: US$640.00 Quantity in Basket: none C70 2.3L HPT 1998 - 2002 ECU Upgrade C70 2.3L HPT 1998 - 2002 ECU Upgrade Code:VLE-275-065 Price: US$640.00 Quantity in Basket: none C70 2.4L LPT 2003 - 2004 ECU Upgrade C70 2.4L LPT 2003 - 2004 ECU Upgrade Code:VLE-275-066 Price: US$640.00 Quantity in Basket: none C70 2.3L HPT 2003 - 2004 ECU Upgrade C70 2.3L HPT 2003 - 2004 ECU Upgrade Code:VLE-275-067 Price: US$640.00 Quantity in Basket: none You will also want to upgrade your exhaust system for good measure to gain full potential from any ECU upgrade. A 3" downpipe to a 2.5" free flowing exhaust system if your not planning on upgrading your TURBO. 3" downpipe and full 3" catback if you are upgrading your TURBO. |
installed a boost gauge...showing 10psi on hpt
cool
What gauge you get?
i needed something to monitor the manual boost controller, running 13.5 psi right now, so i installed a sunpro vacum/boost gauge. not sure of the permanent placement
We just got done installing a used engine in a car that a Cust. had blown up.
It is a 1995 850. The kid installed parts and was messing with stuff and burned a bearing. After installing the motor and testdriving WOW that thing is fast. Then look at the Boost guage and WOW it is running 16PSI BOOST. That is on a Junk Yard engine just dropped in and key turned. The car has the stock computer as well. |
heres a pic of the gauge installed.
http://i1.tinypic.com/s2gz9i.jpg |
You did a nice job with the installation! Your auto certainly looks great..............if only you did not have to have that hunk of metal called a license plate on the front!
Reg |
well yea...that sure is staying on, i got 17 tickets for jsut that, and i lost my patience with that so i just left it on now.
My son has a BMW and he refuses to put a license plate on the front. He has it sitting on his dash so you can see it from the front. That really does dectract from the look of your car, but it still looks great!
Ahhhh those of us who flaunt the law!! I do not place a 'year' sticker on my rear tag as I have a personalized tag and the sticker detracts from the appearance. You would think I would grow up!
for the plate in the window...had a looooooong conversation with the cop when i had it there. he said that if they really wanna be diks about it they can evn go as far as attemped homicide as the plate can be used as a weapon if it flies away from that window. and i guess that does make sense too, that plate can do some mad damage if it goes flying at someone.
Move to Pennsylvania. No front plates there.
hehehe....i dunno bout the moving part...i kinda like this little town called Chicago ;)
Well then, go around the corner to Michigan...........only the rear tag.
Reg ORIGINAL: mladen hehehe....i dunno bout the moving part...i kinda like this little town called Chicago ;) |
| All times are GMT -5. The time now is 07:49 AM. |
