P0236 CEL Code?
Old Nov 3, 2008 | 09:00 PM
Chart's Avatar
Default P0236 CEL Code?
My check engine light came on today, stopped in at AutoZone on the way home and the guy pulled a P0236 code out, which read "The PCM has determined that the input voltage for boost pressure sensor "A" is out of range for the current engine operating conditions."
Not entirely sure what to do about it, possibly a vacuum leak or problem with the sensor?
Anyone with any advice on what to do would be hugely appreciated.
Old Nov 3, 2008 | 09:23 PM
Default RE: P0236 CEL Code?
I believe that is in refrence to the sensor mounted in the hard plastic pipe going to the throttle body.
Make sure the connections are good. If they are the sensor is bad.
Old Nov 3, 2008 | 09:58 PM
Chart's Avatar
I checked the connections and everything looks fine, I think this is the right part
http://www.fcpgroton.com/product-exe...ategory_id/116
Sensor isn't terribly difficult to replace right?
Old Nov 3, 2008 | 10:02 PM
It is either that one or the other one. But they are both really easy to replace.
Old Oct 11, 2019 | 01:03 PM
ehirsh's Avatar
Any idea where that is on a 2005 S40 T5? Is that still on the plastic tube somewhere?
autosys1
Feb 2, 2015 07:25 PM
cjbmustang
Feb 11, 2013 08:11 PM
wakawu
Aug 31, 2010 07:00 AM
steve38
Jun 29, 2008 11:23 AM
leebae
Jun 21, 2007 12:28 AM
