Power Antenna
Well the other day I came back to my car after running some errands and found that somehow my power antenna was bent in half. Which is odd to me since it should have been retracted after turning the car off.
Either way, I fixed it enough so that it goes down but about 2" remains extended at the end. I understand that you can replace the mast rather then replace the whole thing. Dealership wants to charge me 60 for just the mast. While on E-bay there are set ups for complete power antennas for C70's for 25 bucks. But not sure of the quality and if they are truly made for C70's. Anybody have an experience they can send my way? Thanks! |
RE: Power Antenna
Unless it recently changed you can't replace just the mast you need to replace the entire motor and mast.
RE: Power Antenna
Shoot, do you know anything about the ones you can get off of e-bay? Here is the link to one
http://cgi.ebay.com/ebaymotors/POWER...QQcmdZViewItem |
RE: Power Antenna
You can give it a shot it looks close to the OEM one.
RE: Power Antenna
On my c70 I drove through an auto wash when first new and did not even realize that there was a retractable antenna. At any rate, the dealer simply changed the mast which included the white nylon 'strip' inside the mast. $60.00 seems reasonable for the labour and the part. What you are probably getting on ebay (I did not look at the site) is a generic assembly.............one size fits all.
REG |
RE: Power Antenna
ORIGINAL: reg On my c70 I drove through an auto wash when first new and did not even realize that there was a retractable antenna. At any rate, the dealer simply changed the mast which included the white nylon 'strip' inside the mast. $60.00 seems reasonable for the labour and the part. What you are probably getting on ebay (I did not look at the site) is a generic assembly.............one size fits all. REG |
RE: Power Antenna
TECH, I'm almost positive that IPD sells the mast separately. I have seen it advertised before and I thought jeez had I know that I would have changed it myself! I bought my c70 after seeing one in Tampa on a Suday as I was returning the rental. I knew it was a Volvo because of the grille. Monday I called the dealer.............he did not have one and I found one in Cincinati and bought it on Tuesday. I hadn't even been in one let alone looked at one up close..............what I saw in Tampa was an auto that I simply had to have in silver and I got it! I drove it home (north) Tuesday night and hadn't the foggiest idea what the knobs and etc controled. I did figure out how to operate the radio and when I arrived home I drove right to an auto wash (it was winter) and found out that the antenna was external and cost me better than $100.00 the next day to replace!
R. |
RE: Power Antenna
OUCH!!!
We can't even get one from our supplier of OEM parts. |
