Power steering hose
I'm have a question regarding a power steering hose for my 2001 C70, 2.3L---the hose slipped out of its holder and was abraided by the pully, creating a hole that now shoots out fluid. I obviously need to replace the hose, but can anyone give me any information as to exactly which hose (high pressure?? low pressure--there is surprisingly little info out there in regards to this) needs to be replaced so I can do some research online and not get raped by the dealer?? The hose that was abraided is the larger of the two, that runs from the reservoir to the pump beside the engine block. (Not the thin, long hose that runs down behind the engine block).
Thanks for any help--I'm a new Volvo owner and have yet to find a good local mechanic that I trust--so it's the dealer when I have problems!
You have to understand that a Volvo, indeed, any European auto utilizes expensive original parts. If you can't afford them, then you can't afford the Volvo! On the other hand there is a plethora of repair work that you can perform on your Volvo by yourself, however do not be put off by the costly Volvo 'parts'. The original parts generally are worth the extra money spent to purchase them. By the Volvo parts and replace them yourself and Voila............you have saved dollars!
Reg
p.s. For Black Beauty...............'Euros".
Reg
ORIGINAL: funkdog
I'm have a question regarding a power steering hose for my 2001 C70, 2.3L-the hose slipped out of its holder and was abraided by the pully, creating a hole that now shoots out fluid. I obviously need to replace the hose, but can anyone give me any information as to exactly which hose (high pressure?? low pressurethere is surprisingly little info out there in regards to this) needs to be replaced so I can do some research online and not get raped by the dealer?? The hose that was abraided is the larger of the two, that runs from the reservoir to the volvo parts pump beside the engine block. (Not the thin, long hose that runs down behind the engine block).
Thanks for any helpI'm a new Volvo owner and have yet to find a good local mechanic that I trustso it's the dealer when I have problems!
jprizal
01-15-2009 04:05 PM
