TURN OFF CK ENGINE LIGHT
Old Nov 23, 2007 | 07:59 PM
01c70driver's Avatar
Default TURN OFF CK ENGINE LIGHT
Hey Volvo Peoples,
Can ya all tell me how to reset the ck engine light on a 01 c70? I would appreciate the help. THANKS
Old Nov 23, 2007 | 08:06 PM
PANTYEATR's Avatar
Default RE: TURN OFF CK ENGINE LIGHT
either pull the ECU fuse or diconnect the batteryfor like 2 mins. if it comes back on you have a problem.
Old Nov 23, 2007 | 11:46 PM
tripleb's Avatar
I would pull the fuse, unless you have the radio code. Then it doesn't matter, except it's easier to pull the fuse.
B
Old Nov 24, 2007 | 09:57 AM
PANTYEATR's Avatar
raido code??? i had a scare with my ETM and i pulled the fuse for the tranny, ECM and the ETM, but the battery was left hooked up. i didn't have to input a radio code though.
is that hard to put in?
Old Nov 24, 2007 | 10:17 AM
tripleb's Avatar
It is easy, but you need it if you disconnect the battery.
It's a 4 digit code that you input into the radio using the 1-6 preset buttons.
Somwtimes it's included in you car information booklet, or you can get it from a dealer.
B
Old Nov 24, 2007 | 11:48 AM
PANTYEATR's Avatar
damn, see i bought my C70 used, so i have to look in the stuff that came with the car to see if there is a code inside.
Old Nov 26, 2007 | 12:43 PM
If not have the Volvo store look the code up.
suckonthiscaravan
Dec 5, 2018 03:19 PM
RyanHeaslipVermont
Aug 24, 2011 10:41 AM
96960Chris
Oct 27, 2010 11:43 AM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
