[HELP] Water Leak in my 2005 Volvo S40 T5
Old 09-23-2015, 08:33 AM
dadclarkus's Avatar
Please share your method for re-installing the drain plugs for the sunroof drain. The driver's side wasn't that hard, the passenger side is eating my breakfast, lunch and dinner. Thank you
  #22
Old 09-24-2015, 10:54 AM
mf70's Avatar
I'm not sure who you're asking, but as a four-times veteran of the process, here's my take:
You can get access to the back area by removing the apron molding that goes under the windshield wipers (The two center fasteners are 90 deg turn catches, different than any other Volvo fastener)
The Elbows lead down through the firewall and project through a slightly larger access hole into the space below the hood hinges. In its final position, the tip of the elbow can be felt in that larger access hole.
I used, at various times, a wire leader inserted into the hole first and a 1/2" copper pipe "tool" to snap the elbow into the hole. The dash molding also can flex slightly to give a little more room.
My last resort would be threading a longer piece of tubing through both holes and joining it to the down pipe with some sort of coupler.
benscab123
01-25-2011 02:13 PM
illfrom
03-07-2010 09:15 AM
jasonl
09-01-2009 05:00 PM
flapper
10-22-2007 05:56 PM
Quick Reply: [HELP] Water Leak in my 2005 Volvo S40 T5
