01 S40 Cyl #4 Misfire, tried everything!
Old May 22, 2011 | 06:37 PM
NFrank89's Avatar
Default 01 S40 Cyl #4 Misfire, tried everything!
Already swapped plugs, coils, and injectors with other cylinders. also ran compression on all cylinders, resistance on both coils and all injectors, everything is consistent and within spec. #4 continues to drop a misfire CEL. any ideas? the misfire can be felt throughout the rpm range, including idle
Old May 23, 2011 | 06:54 AM
Hudini's Avatar
Replace the coils.
Like you, I tested coil resistance, ohmed the wires, replaced the plugs, even pulled the fuel injectors and cleaned them with a home made rig. All checked good. I then broke down and replaced the coils and all was well.
Autozone had coils in stock for $44 each (at the time). I thought they would be el-cheapo chinese knock-offs but was pleasantly surprised when an OEM Volvo coil came out of the Duralast box.
Old May 23, 2011 | 03:10 PM
plumber_nc's Avatar
Replace the coils.
I had the same problem and bought the AZ coils (OEM Volvo) and everything is fine now.
Old May 24, 2011 | 12:59 PM
NFrank89's Avatar
Replaced the plugs with autolite double platinums and the misfire disappeared!
Old May 25, 2011 | 05:21 AM
mrford55's Avatar
had the same thing i changed coils and had to do the wires.wires were breaking down under a load.
ajamesr
1998-2000 model year V70
Feb 19, 2023 09:13 AM
Ethan Morrisson
Engine & Internal
Dec 21, 2012 04:31 AM
nellers1988
Oct 19, 2011 12:34 PM
OKC_Dave
Jun 25, 2009 05:42 PM
rgmendoza
Mar 13, 2009 08:39 PM
