01 s40 pollen filter or cabin filter, where?
Hello,
I'm wondering if anyone can tell me where the location of the pollen filter (or cabin filter) is in the 01 s40? thanks |
RE: 01 s40 pollen filter or cabin filter, where?
Remove the lower carpeted dash panel. Then look foward and you should see a skinny panel that goes from the front of the box towards the back. You push a clip in and the panel will drop down and the filter is in there.
Where on the car are you referring to? It sounds like a foot well? where, passenger side or driver?
more details please |
Yes passenger side footwell if it is a use car.
Nigel ,
i also need to change mine.. If you are able to change yours could you pls add some pictures of how you did it ? Specially on where to locate it ? Best Regards |
Found these very detailed instructions to follow.. Used them fine !
Where is the cabin filter on C70 2008??
Best if you post on the C70 forum. Maybe someone here in the S40 forum knows but more likely over there.
4 Attachment(s)
I've replaced cabin (pollen) filter recently and have some pictures from shor manual bought with the replacement. Hope it will help:
Attachment 18571 Attachment 18572 Attachment 18573 Attachment 18574 |
