01 tps
I'm going to change the TPS on my '01 S40.
Any tips would be appreciated. |
You are the first person I've ever heard of changing it. What prompted the work?
I've got a distinct ruff running at about half throttle, irregardless of RPM.
I've changed plugs and one coil. |
Turns out it's not that hard to do.
First, I got the P/N from autopartswarehouse I copied the # and pasted it in Amazon - it's cheaper (just a bit) and I get free shipping - also ordered an oil filter and some non-auto stuff. Remove the air inlet hose - from the intercooler to the throttle body (tb), looks like a big radiator hose. Shoulda given the clamps a spurt of penetrating oil. Use pliers to retract the clamps on 2 vac lines between the tb and exh manifold. Then disconnect the hoses. Loosen / remove 4 tb bolts - a 10mm deep socket came in handy. Remove the retaining clip from the throttle cable bracket above/behind tb. Lift tb enough to remove the throttle cable from the bracket. Lift & rotate tb to disconnect the tps wire connector - I hadda look at the new one to know which side of the connector the release tab is on. Re-installation is pretty straight. I had to look at the old tps to know the orientation of the wire connector and again for which side the wire connector release tab is on... I turned on the ignition and pressed the throttle all the way and released it. Ignition off and back on, then started it up. |
| All times are GMT -5. The time now is 12:39 AM. |
