-   Volvo S40 (https://volvoforums.com/forum/volvo-s40-11/)
-   -   2000 s40 Engine revs and accelerating (https://volvoforums.com/forum/volvo-s40-11/2000-s40-engine-revs-accelerating-11385/)
ccmjr77 May 7, 2007 07:12 PM
My 2000 S40 starting revving/accelerating without using the gas pedal. Had to keep the brake firmly down to keep from going through a stop sign.
What would cause this? It scared my wife, where she will not even ride in the car.
Any ideas?
thanks,
vasilisuk May 8, 2007 03:38 AM
RE: 2000 s40 Engine revs and accelerating
I would firstly check the throtle wire for any broken branches and after that I would check the throtle sensor for any dirty contacts or similar electrical mulfunction. I know the solution sounds simple for such a serious problem but I guess it is better to start from the simple staff. Good luck
beemer330 May 10, 2007 08:56 AM
Did you replace your spark plugs recently? I had the same accelerating problem. Reading through these forums, and reading the topic 'spark plugs' everyone recommended copper core spark plugs. i was sold Champion Double Platinum plugs at the store originally and then when i switched to NGK copper core plugs the problem went away.
