Low beams still not working
Old 03-09-2014, 07:36 PM
4n6pi's Avatar
Default Low beams still not working
Hi guys,
I was thrilled at first when I found this post:
https://volvoforums.com/forum/volvo-...working-37696/
....but after I bought the relays then took my dash apart low and behold those relays are working fine and I have power from the switch to the CEM and to the fuse box but not the low beams??? Does anyone have the wiring diagram so I can follow from the fuseBox? My high beams are fine and I bought new bulbs just because. anyone have any idea what to check next???
thanks
Old 03-09-2014, 07:40 PM
Did you install the new bulbs?
Have you checked for power at the light assembly?
Do you have HID's?
Have you checked the main head light switch?
Old 03-10-2014, 06:42 PM
4n6pi's Avatar
Do you have HID's?
Yes
Yes no power
No
Yes
Old 03-11-2014, 08:50 PM
4n6pi's Avatar
Default Traced things a bit further
OK, so I traced the wires all the way to the headlight assembly/ Housing and I have power at the harness that plugs into the assembly. Thats all I can do without taking the assembly out. I attached an image I got off EBay of the same light housing as I have(so you can see what I was talking about) , what is the blue plug for and why do I have power to it on both driver and passenger sides but no low beams???
Thank you
Old 07-22-2014, 05:51 PM
KLR142's Avatar
Did you get this solved? What was it? Bad harness inside the headlight assembly?
98isb360
10-13-2021 08:47 AM
bkhan145
03-16-2019 02:22 PM
S80inVA
01-24-2011 08:58 PM
MarkyD
09-05-2006 08:01 PM
KESchumacher
04-18-2006 08:33 PM
Quick Reply: Low beams still not working
